跳转到主内容
加入维修社区 - 创建账户
Lamp Switch Replacement
你所需要的
  1. Lamp Switch Replacement, Switch: 步骤 1 中的图像 1,1
    • Unplug the lamp from the wall to reduce the risk of electric shock.
    询问修复机器人
    添加评论
  2. Lamp Switch Replacement: 步骤 2 中的图像 1,1
    • Unscrew the light bulb from the socket then remove the lamp shade.
    询问修复机器人
    添加评论
  3. Lamp Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws from the bottom inside the socket. These screws hold the silver threaded socket in place.
    询问修复机器人
    添加评论
  4. Lamp Switch Replacement: 步骤 4 中的图像 1,1
    • When the screws are removed, the threaded socket will pull out.
    询问修复机器人
    添加评论
  5. Lamp Switch Replacement: 步骤 5 中的图像 1,1
    • Unscrew and remove the outer black socket body.
    询问修复机器人
    添加评论
  6. Lamp Switch Replacement: 步骤 6 中的图像 1,1
    • Partially peel back the felt or cork from bottom of the lamp to gain access to power cord. Take care to avoid tearing.
    询问修复机器人
    添加评论
  7. Lamp Switch Replacement: 步骤 7 中的图像 1,1
    • Push a few inches of the power cord upwards to gain slack to work with. Some cords may have a knot tied here which will need loosened to push slack upwards.
    询问修复机器人
    添加评论
  8. Lamp Switch Replacement: 步骤 8 中的图像 1,1
    • Pull the socket base/switch assembly out of the base to gain access to the screw terminals on the sides.
    询问修复机器人
    添加评论
  9. Lamp Switch Replacement: 步骤 9 中的图像 1,1
    • Unscrew the terminals on each side to release the wires. The screws may be retained so they may not come all the way out.
    询问修复机器人
    添加评论
  10. Lamp Switch Replacement: 步骤 10 中的图像 1,1
    • Attach the wires to the new switch assembly. It doesn't matter which wire goes to which terminal. For a secure connection, bend a hook into the end of the wire and orient it on the screw so the hook closes when the screw is tightened.
    询问修复机器人
    添加评论
  11. Lamp Switch Replacement: 步骤 11 中的图像 1,1
    • Position the socket/switch assembly on the base and pull the power cord from the bottom to set the socket in place. Reattach the felt or cork on the bottom of the lamp.
    询问修复机器人
    添加评论
  12. Lamp Switch Replacement: 步骤 12 中的图像 1,1
    • Pushing downward to hold the socket in place, screw the black outer socket back in place to secure the switch.
    询问修复机器人
    添加评论
  13. Lamp Switch Replacement: 步骤 13 中的图像 1,1
    • Set the sliver threaded socket into place. Turn the socket to align the two screw holes.
    询问修复机器人
    添加评论
  14. Lamp Switch Replacement: 步骤 14 中的图像 1,1
    • Screw in the two screws to secure the threaded silver socket into place.
    询问修复机器人
    添加评论
  15. Lamp Switch Replacement: 步骤 15 中的图像 1,1
    • Reattach the lamp shade and screw in the light bulb.
    询问修复机器人
    添加评论
结论
After following these steps to replace a non-working switch, you should again have a functional lamp.
取消:我没有完成这个指南。
10等其他人完成本指南。
Matt Plueger
于02/10/16注册
363 声望
撰写一个指南
团队
Colorado Springs, Team 8-5, Mcmichael Fall 2016 Colorado Springs, Team 8-5, Mcmichael Fall 2016 的会员
UCCS-MCMICHAEL-F16S8G5
3 名成员
创作了1篇指南
2指南评论
A very nice and clear explanation. Unfortunately the pull chain switch in my lap was riveted to the socket so I had to replace the entire socket. It really was easy though and required less steps than your switch replacement. Here’s a video that shows exactly what I did: https://youtu.be/0fLnUPWzLeI
Thanks!
Scott Clark - 回复 分享
WOW! I almost threw away my fav Lil lamp - vacuuming I tipped over the lamp and it cracked the threaded plastic part - I followed your instructions and now have a nonflickering - fully functioning lamp! Thanks perfect timing
anggnbama - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 95
总计 14,711
