跳转到主内容
Lamp Pull Chain Replacement
你所需要的
  1. Lamp Pull Chain Replacement, Lamp Pull Chain: 步骤 1 中的图像 1,1
    • Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
  2. Lamp Pull Chain Replacement: 步骤 2 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 2 中的图像 2,2
    • Remove the light bulb from the lamp.
  3. Lamp Pull Chain Replacement: 步骤 3 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 3 中的图像 2,2
    • Unscrew the lamp shade from the base by turning it counter-clockwise.
  4. Lamp Pull Chain Replacement: 步骤 4 中的图像 1,1
    • Gently pull the socket from the base to expose the broken chain section.
  5. Lamp Pull Chain Replacement: 步骤 5 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 5 中的图像 2,2
    • Attach the chain connector to the extra chain.
  6. Lamp Pull Chain Replacement: 步骤 6 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 6 中的图像 2,2
    • Connect the chain with the chain connector to the broken chain on the lamp base.
  7. Lamp Pull Chain Replacement: 步骤 7 中的图像 1,3 Lamp Pull Chain Replacement: 步骤 7 中的图像 2,3 Lamp Pull Chain Replacement: 步骤 7 中的图像 3,3
    • Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp.
    • The chain will go down through this hole.
  8. Lamp Pull Chain Replacement: 步骤 8 中的图像 1,1
    • Gently push the socket back into place.
  9. Lamp Pull Chain Replacement: 步骤 9 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 9 中的图像 2,2
    • Screw the lamp shade back onto the base of the lamp by turning it clockwise.
  10. Lamp Pull Chain Replacement: 步骤 10 中的图像 1,1
    • Replace the light bulb into the lamp socket.
  11. Lamp Pull Chain Replacement: 步骤 11 中的图像 1,2 Lamp Pull Chain Replacement: 步骤 11 中的图像 2,2
    • Plug your lamp into an outlet and turn it on!
    • You will pull down on the chain to do this.
  12. Lamp Pull Chain Replacement: 步骤 12 中的图像 1,1
    • Congratulations! You have fixed your lamp.
结论
Congratulations on fixing your lamp!
3等其他人完成本指南。
4条评论
You saved my lamp! Thank you for this simple to follow guide.
Erica Chiovarou - 回复
All well and good, but isn’t it more likely that the break will be in the string which runs from the chain into the switch? This can be fixed by disassembling the switch itself - but where can one buy the right string?
gregg.horne - 回复
On my lamp, the problem was not the chain but in the switch itself. This made it necessary to replace the entire socket since the switch was riveted to its base. I made this video which shows how to replace the socket and switch:https://youtu.be/0fLnUPWzLeI
Scott Clark - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 197
过去 30 天: 749
总计 26,773
