跳转到主内容
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
你所需要的
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: 步骤 1 中的图像 1,1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 2 中的图像 1,1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 3 中的图像 1,2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 3 中的图像 2,2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 4 中的图像 1,2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 4 中的图像 2,2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 5 中的图像 1,2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 5 中的图像 2,2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 6 中的图像 1,1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 7 中的图像 1,3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 7 中的图像 2,3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 7 中的图像 3,3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 8 中的图像 1,1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 9 中的图像 1,2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 9 中的图像 2,2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 10 中的图像 1,2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 10 中的图像 2,2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 步骤 11 中的图像 1,1
    • Gently pull the hose to ensure it is secure.
结论
另外一个人完成了本指南。
一条评论
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 797
