跳转到主内容
LaCie Rugged USB-C Hard Drive Replacement
你所需要的
  1. LaCie Rugged USB-C Hard Drive Replacement, Overview: 步骤 1 中的图像 1,3 LaCie Rugged USB-C Hard Drive Replacement, Overview: 步骤 1 中的图像 2,3 LaCie Rugged USB-C Hard Drive Replacement, Overview: 步骤 1 中的图像 3,3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: 步骤 2 中的图像 1,2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: 步骤 2 中的图像 2,2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: 步骤 3 中的图像 1,2 LaCie Rugged USB-C Hard Drive Replacement, Case Screws: 步骤 3 中的图像 2,2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: 步骤 4 中的图像 1,2 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: 步骤 4 中的图像 2,2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: 步骤 5 中的图像 1,2 LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: 步骤 5 中的图像 2,2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Hard Drive Replacement, Drive Removal: 步骤 6 中的图像 1,1
    • Pull the drive gently out of the SATA connector.
结论
6等其他人完成本指南。
9021007
于07/13/18注册
4,562 声望
创作了25篇指南
4条评论
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy Gibbons - 回复
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Dion Diogo Mar -
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
James Causey - 回复
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 163
总计 3,635
