跳转到主内容
LaCie Rugged USB-C Circuit Board Replacement
你所需要的
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: 步骤 1 中的图像 1,3 LaCie Rugged USB-C Circuit Board Replacement, Overview: 步骤 1 中的图像 2,3 LaCie Rugged USB-C Circuit Board Replacement, Overview: 步骤 1 中的图像 3,3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: 步骤 2 中的图像 1,2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: 步骤 2 中的图像 2,2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: 步骤 3 中的图像 1,2 LaCie Rugged USB-C Circuit Board Replacement, Case Screws: 步骤 3 中的图像 2,2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: 步骤 4 中的图像 1,2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: 步骤 4 中的图像 2,2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: 步骤 5 中的图像 1,2 LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: 步骤 5 中的图像 2,2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: 步骤 6 中的图像 1,1
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: 步骤 7 中的图像 1,1
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: 步骤 8 中的图像 1,1
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
结论
5等其他人完成本指南。
9021007
于07/13/18注册
4,562 声望
创作了25篇指南
3条评论
Where can i get a new board? thank you
Bar Avraham - 回复
Yes, where can we find a new board?
Vassilis Trigkas - 回复
Right, where can the part be purchased?????
James Causey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 50
总计 1,142
