跳转到主内容
  1. Remove the two plastic screw covers below the inside phone screen. Remove the two plastic screw covers below the inside phone screen.
    • Remove the two plastic screw covers below the inside phone screen.
  2. Unscrew both screws using a Torx T6 screwdriver.
    • Unscrew both screws using a Torx T6 screwdriver.
  3. Pry off the screen front cover with a 3mm flathead screwdriver. Pry off the screen front cover with a 3mm flathead screwdriver. Pry off the screen front cover with a 3mm flathead screwdriver.
    • Pry off the screen front cover with a 3mm flathead screwdriver.
  4. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver. Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver.
    • Pry off the speaker, which is glued onto the front cover, using a small flathead screwdriver.
  5. Unsolder the black and red wires of the speaker from where they are attached to the base of the screen.
    • Unsolder the black and red wires of the speaker from where they are attached to the base of the screen.
  6. Obtain replacement speaker and solder the new black and red wires back to the base of the screen.
    • Obtain replacement speaker and solder the new black and red wires back to the base of the screen.
  7. Apply glue to the back of the speaker and place it back in its original position.
    • Apply glue to the back of the speaker and place it back in its original position.
结论
另外一个人完成了本指南。
Nicholas Schmidt
于2010年10月09日注册
97 信誉积分
创作了7篇指南
团队
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G25
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 737
