跳转到主内容
LG-A275 Speaker Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    LG-A275 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 LG-A275 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG-A275 Speaker Replacement, Remove cover: 步骤 2 中的图像 1,2 LG-A275 Speaker Replacement, Remove cover: 步骤 2 中的图像 2,2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG-A275 Speaker Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the device.
  4. LG-A275 Speaker Replacement, Speaker: 步骤 4 中的图像 1,3 LG-A275 Speaker Replacement, Speaker: 步骤 4 中的图像 2,3 LG-A275 Speaker Replacement, Speaker: 步骤 4 中的图像 3,3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the opening tool not to use brute force and potentially break the fragile phone plastics.
  5. LG-A275 Speaker Replacement: 步骤 5 中的图像 1,3 LG-A275 Speaker Replacement: 步骤 5 中的图像 2,3 LG-A275 Speaker Replacement: 步骤 5 中的图像 3,3
    • After separating the front and back components of the phone, proceed to take off the motherboard. This can be done by releasing the plastic clamps on the corners and edges of the plastic front using your fingernail.
    • Be careful when doing this to avoid breaking the phone plastics, it should release easily.
  6. LG-A275 Speaker Replacement: 步骤 6 中的图像 1,3 LG-A275 Speaker Replacement: 步骤 6 中的图像 2,3 LG-A275 Speaker Replacement: 步骤 6 中的图像 3,3
    • Lastly remove the speaker using the plastic opening tool.
结论
Nathanael Knight
于03/27/18注册
181 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Harley Spring 2018 IUPUI, Team S3-G1, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S3G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 218
