你所需要的
LG Washer, OE error code message. Washing cycle doesn't finish, water doesn't drain. CLOGGED DRAIN PUMP FILTER.
Related video: https://www.facebook.com/100004990830507...
To assist in opening the filter cover, we can use a blunt knife or a flat screwdriver.
The pump is located in the bottom tray, we need to turn the filter cap a couple of turns, WITHOUT UNSCREWING IT COMPLETELY, this way we are slowly opening and closing to drain the water slowly without flooding the room.
This is a home made tool that I also use to check the pump's propeller without having to remove it.
This is a PVC tube, 16 mm by 20 cm (tube used for electrical installations). I used a saw and a small file to make four slits on one end so I can grip the propeller and confirm if it rotates or not.
The tube is inserted to grip the propeller, then it needs to be rotated to confirm if there is any issue or resistance when turning (damaged motor).
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
