当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
Place the phone face down on the table.
Use your fingernail or an opening tool to pull down the tab below the battery.
Lift the battery out.
Locate the seam around the edge of the phone.
Insert the plastic opening tool into the seam and pry gently to release the tabs.
Work your way around the phone until all tabs are released.
Remove the back panel of the phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
