跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
In this guide you will be taking off the back panel to access and remove the side volume and camera buttons.
配件
没有特定配件。
  1. Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone facedown on the table.
    • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
    • Lift the battery out.
  2. Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  5. Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  6. Locate the volume and camera buttons on the right side of the phone. Lift up on the buttons to slide them out of the phone.
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
结论
Reed Williston
于2012年09月26日注册
34 信誉积分
创作了7篇指南
团队
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G55
5 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 418
