跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
LG env2 vx9100 Front Panel Replacement
你所需要的
  1. LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 1,3 LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 2,3 LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Front Panel Replacement, Back Panel: 步骤 2 中的图像 1,2 LG env2 vx9100 Front Panel Replacement, Back Panel: 步骤 2 中的图像 2,2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Front Panel Replacement: 步骤 3 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 3 中的图像 2,2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Front Panel Replacement: 步骤 4 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Front Panel Replacement, Front Panel: 步骤 5 中的图像 1,2 LG env2 vx9100 Front Panel Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Locate the rubber covers at the top two corners of the inside of the phone.
    • Use the metal probe to remove the rubber covers to reveal the 2.5mm screws.
  6. LG env2 vx9100 Front Panel Replacement: 步骤 6 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 6 中的图像 2,2
    • Locate the 2.5mm screws that were underneath the rubber covers.
    • Use a #00 Phillips screwdriver to remove both 2.5mm screws.
  7. LG env2 vx9100 Front Panel Replacement: 步骤 7 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 7 中的图像 2,2
    • Locate the two 2.5mm screws at the bottom two corners of the inside of the phone.
    • These screws will not be visible or accessible unless the 2 sides of the phone are at approximately 90 degrees relative to each other.
  8. LG env2 vx9100 Front Panel Replacement: 步骤 8 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 8 中的图像 2,2
    • Locate the crease that travels all around the edge of the phone.
    • Wedge the plastic opening tool in the crease and move it along each edge of the phone.
    • Separate the front panel from the rest of the phone.
    • Be careful not to damage the orange ribbon that connects to the logic board through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
    • Open the phone to reveal the inside monitor.
  9. LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 1,3 LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 2,3 LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 3,3
    • Locate the two 2.5mm screws to the right of the screen (on the photograph shown they are at the bottom).
    • Using your hands separate the front panel from the phone by carefully pulling it straight off.
结论
Reed Williston
于09/26/12注册
34 声望
创作了7篇指南
团队
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G55
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,532
