跳转到主内容
加入维修社区 - 创建账户
LG env2 vx9100 Front Panel Replacement
你所需要的
  1. LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 1,3 LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 2,3 LG env2 vx9100 Front Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Front Panel Replacement, Back Panel: 步骤 2 中的图像 1,2 LG env2 vx9100 Front Panel Replacement, Back Panel: 步骤 2 中的图像 2,2
    • Locate the five rubber covers on the back panel of the phone.
    • Use a metal probe to remove each rubber cover and expose the screws underneath.
  3. LG env2 vx9100 Front Panel Replacement: 步骤 3 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 3 中的图像 2,2
    • Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
    • Remove all six screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Front Panel Replacement: 步骤 4 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 4 中的图像 2,2
    • Locate the seam around the edge of the phone.
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Front Panel Replacement, Front Panel: 步骤 5 中的图像 1,2 LG env2 vx9100 Front Panel Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Use a spudger to pry the two rubber covers out of the device.
  6. LG env2 vx9100 Front Panel Replacement: 步骤 6 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove two 2.5 mm screws.
  7. LG env2 vx9100 Front Panel Replacement: 步骤 7 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 7 中的图像 2,2
    • These screws will not be visible or accessible unless the two sides of the phone are at approximately 90 degrees relative to each other.
  8. LG env2 vx9100 Front Panel Replacement: 步骤 8 中的图像 1,2 LG env2 vx9100 Front Panel Replacement: 步骤 8 中的图像 2,2
    • Insert the plastic opening tool in the crease and move it along each edge of the phone.
    • Separate the front panel from the rest of the phone.
    • Be careful not to damage the orange ribbon that connects to the motherboard through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
    • Open the phone to reveal the inside monitor.
  9. LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 1,3 LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 2,3 LG env2 vx9100 Front Panel Replacement: 步骤 9 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove two 2.5mm screws.
    • Using your hands, separate the front panel from the phone by carefully pulling it straight off.
结论
Reed Williston
于09/26/12注册
34 声望
创作了7篇指南
团队
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G55
5 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 1,692
