跳转到主内容
加入维修社区 - 创建账户
LG env2 vx9100 Camera Replacement
你所需要的
  1. LG env2 vx9100 Camera Replacement, Battery: 步骤 1 中的图像 1,3 LG env2 vx9100 Camera Replacement, Battery: 步骤 1 中的图像 2,3 LG env2 vx9100 Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Camera Replacement, Back Panel: 步骤 2 中的图像 1,2 LG env2 vx9100 Camera Replacement, Back Panel: 步骤 2 中的图像 2,2
    • Locate the five rubber covers on the back panel of the phone.
    • Use a metal probe to remove each rubber cover and expose the screws underneath.
  3. LG env2 vx9100 Camera Replacement: 步骤 3 中的图像 1,2 LG env2 vx9100 Camera Replacement: 步骤 3 中的图像 2,2
    • Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
    • Remove all six screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Camera Replacement: 步骤 4 中的图像 1,2 LG env2 vx9100 Camera Replacement: 步骤 4 中的图像 2,2
    • Locate the seam around the edge of the phone.
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Camera Replacement, Camera: 步骤 5 中的图像 1,2 LG env2 vx9100 Camera Replacement, Camera: 步骤 5 中的图像 2,2
    • Locate the ribbon attached to the lens of the camera.
    • Place the plastic opening tool in between the logic board and ribbon.
    • Lift up the plastic opening to detach the ribbon from the logic board.
  6. LG env2 vx9100 Camera Replacement: 步骤 6 中的图像 1,2 LG env2 vx9100 Camera Replacement: 步骤 6 中的图像 2,2
    • Place the plastic opening tool in between the lens and the logic board.
    • Detach the lens from the logic board using the plastic opening tool by popping it out.
    • Take the entire lens and ribbon off of the logic board.
结论
另外一个人完成了本指南。
Reed Williston
于09/26/12注册
34 声望
创作了7篇指南
团队
Cal Poly, Team 16-55, Forte Fall 2012 Cal Poly, Team 16-55, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G55
5 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 537
