跳转到主内容
LG X Style Front Facing Camera Replacement
你所需要的
  1. LG X Style Front Facing Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Front Facing Camera Replacement: 步骤 2 中的图像 1,2 LG X Style Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Front Facing Camera Replacement, Screen: 步骤 3 中的图像 1,2 LG X Style Front Facing Camera Replacement, Screen: 步骤 3 中的图像 2,2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Front Facing Camera Replacement: 步骤 4 中的图像 1,3 LG X Style Front Facing Camera Replacement: 步骤 4 中的图像 2,3 LG X Style Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Front Facing Camera Replacement, Motherboard: 步骤 5 中的图像 1,2 LG X Style Front Facing Camera Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, carefully slide the edge of the tool under the press fit cable connections and lift up to disconnect. Do this for all three ribbon cables.
  6. LG X Style Front Facing Camera Replacement: 步骤 6 中的图像 1,3 LG X Style Front Facing Camera Replacement: 步骤 6 中的图像 2,3 LG X Style Front Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Using the iFixit opening tool, remove the motherboard from the screen by inserting the opening tool under the edge of the motherboard and lifting up.
  7. LG X Style Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 1,2 LG X Style Front Facing Camera Replacement, Front Facing Camera: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the nylon tipped reverse tweezers, remove the front facing camera.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 148
