跳转到主内容
加入维修社区 - 创建账户
LG X Style Camera Flash Replacement
你所需要的
  1. LG X Style Camera Flash Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Camera Flash Replacement: 步骤 2 中的图像 1,2 LG X Style Camera Flash Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Camera Flash Replacement, Screen: 步骤 3 中的图像 1,2 LG X Style Camera Flash Replacement, Screen: 步骤 3 中的图像 2,2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Camera Flash Replacement: 步骤 4 中的图像 1,3 LG X Style Camera Flash Replacement: 步骤 4 中的图像 2,3 LG X Style Camera Flash Replacement: 步骤 4 中的图像 3,3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Camera Flash Replacement, Camera Flash: 步骤 5 中的图像 1,2 LG X Style Camera Flash Replacement, Camera Flash: 步骤 5 中的图像 2,2
    • Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
    • Carefully lift the metal connection perpendicular to the mother board.
  6. LG X Style Camera Flash Replacement: 步骤 6 中的图像 1,2 LG X Style Camera Flash Replacement: 步骤 6 中的图像 2,2
    • Gently lift the camera ribbon cable until the entire front camera housing is removed.
  7. LG X Style Camera Flash Replacement: 步骤 7 中的图像 1,3 LG X Style Camera Flash Replacement: 步骤 7 中的图像 2,3 LG X Style Camera Flash Replacement: 步骤 7 中的图像 3,3
    • Use the opening tool, gently pry up along the edge of the motherboard.
    • Gently pull up and remove the motherboard from the device.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 405
