跳转到主内容
加入维修社区 - 创建账户
LG Watch Urbane Screen Replacement
你所需要的
  1. LG Watch Urbane Screen Replacement, Battery: 步骤 1 中的图像 1,2 LG Watch Urbane Screen Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Screen Replacement: 步骤 2 中的图像 1,2 LG Watch Urbane Screen Replacement: 步骤 2 中的图像 2,2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Screen Replacement: 步骤 3 中的图像 1,3 LG Watch Urbane Screen Replacement: 步骤 3 中的图像 2,3 LG Watch Urbane Screen Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Screen Replacement: 步骤 4 中的图像 1,3 LG Watch Urbane Screen Replacement: 步骤 4 中的图像 2,3 LG Watch Urbane Screen Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Screen Replacement, Screen: 步骤 5 中的图像 1,2 LG Watch Urbane Screen Replacement, Screen: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $19.95
    • Now that you have removed the motherboard and battery, it is time to remove the dock connector.
    • Using a PH000 screwdriver, remove the two screws in order to release the dock connector from the watch.
    • Do not lose the two screws! Keep them somewhere you will remember! A magnetic mat can help with this. iFixit Magnetic Mat
  6. LG Watch Urbane Screen Replacement: 步骤 6 中的图像 1,2 LG Watch Urbane Screen Replacement: 步骤 6 中的图像 2,2
    • Once the screws are removed, the dock connector is free to be moved.
    • Gently lift the dock connector away from the frame and you will now be able to see the screen.
    • The watch's screen is stuck to the back of the glass with an adhesive so be tedious when pulling it off.
结论
另外一个人完成了本指南。
Luis Guinand
于08/31/15注册
151 声望
撰写一个指南
团队
USF Tampa, Team 1-4, Remmell Fall 2015 USF Tampa, Team 1-4, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G4
4 名成员
创作了5篇指南
2指南评论
where i can find watch urbane display ?
melancholie - 回复
Does anyone know where to buy the display?
James Elmore - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 2,611
