跳转到主内容
LG Watch Urbane Battery Replacement
你所需要的
  1. LG Watch Urbane Battery Replacement, Battery: 步骤 1 中的图像 1,2 LG Watch Urbane Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: 步骤 2 中的图像 1,2 LG Watch Urbane Battery Replacement: 步骤 2 中的图像 2,2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: 步骤 3 中的图像 1,3 LG Watch Urbane Battery Replacement: 步骤 3 中的图像 2,3 LG Watch Urbane Battery Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: 步骤 4 中的图像 1,3 LG Watch Urbane Battery Replacement: 步骤 4 中的图像 2,3 LG Watch Urbane Battery Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
结论
18等其他人完成本指南。
Rey Diaz
于08/31/15注册
699 声望
创作了2篇指南
团队
USF Tampa, Team 1-4, Remmell Fall 2015 USF Tampa, Team 1-4, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G4
4 名成员
创作了4篇指南
11条评论
"pried" not "pryed"
Patty Remmell - 回复
Where do I find a replacement battery?
nickpfau - 回复
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - 回复
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 38
总计 15,380
