跳转到主内容
加入维修社区 - 创建账户
LG Watch Urbane Battery Case Replacement
你所需要的
  1. LG Watch Urbane Battery Case  Replacement, Battery: 步骤 1 中的图像 1,2 LG Watch Urbane Battery Case  Replacement, Battery: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Case  Replacement: 步骤 2 中的图像 1,2 LG Watch Urbane Battery Case  Replacement: 步骤 2 中的图像 2,2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Case  Replacement: 步骤 3 中的图像 1,3 LG Watch Urbane Battery Case  Replacement: 步骤 3 中的图像 2,3 LG Watch Urbane Battery Case  Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Case  Replacement: 步骤 4 中的图像 1,3 LG Watch Urbane Battery Case  Replacement: 步骤 4 中的图像 2,3 LG Watch Urbane Battery Case  Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Battery Case  Replacement, Battery Case: 步骤 5 中的图像 1,2 LG Watch Urbane Battery Case  Replacement, Battery Case: 步骤 5 中的图像 2,2
    • Use the PH000 screwdriver to remove the two highlighted screws to release the battery
  6. LG Watch Urbane Battery Case  Replacement: 步骤 6 中的图像 1,1
    • Carefully pinch out the battery case with your fingers to remove it from the face of the watch.
结论
另外一个人完成了本指南。
Philip Sears
于08/31/15注册
195 声望
撰写一个指南
团队
USF Tampa, Team 1-4, Remmell Fall 2015 USF Tampa, Team 1-4, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G4
4 名成员
创作了5篇指南
1指南评论
Where to buy a battery to replacement
sdptuananh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,245
