跳转到主内容
加入维修社区 - 创建账户
LG WM3050CW Pressure Sensor Replacement
你所需要的
  1. LG WM3050CW Pressure Sensor Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG WM3050CW Pressure Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Pressure Sensor Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Pressure Sensor Replacement: 步骤 4 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: 步骤 5 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement, Disconnect the pressure sensor: 步骤 5 中的图像 2,2
    • Disconnect the spade connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Pressure Sensor Replacement: 步骤 6 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement: 步骤 6 中的图像 2,2
    • Disconnect the hose from the pressure sensor.
  7. LG WM3050CW Pressure Sensor Replacement, Unfasten the pressure sensor: 步骤 7 中的图像 1,1
    • Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
  8. LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: 步骤 8 中的图像 1,3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: 步骤 8 中的图像 2,3 LG WM3050CW Pressure Sensor Replacement, Remove the pressure sensor: 步骤 8 中的图像 3,3
    • Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
  9. LG WM3050CW Pressure Sensor Replacement: 步骤 9 中的图像 1,2 LG WM3050CW Pressure Sensor Replacement: 步骤 9 中的图像 2,2
    • Lift the pressure sensor away from its slot on the main board cover to remove it.
    • During reassembly, align the pressure sensor with the hole next to its slot before rotating it back into its original position.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
38,785 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,046篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 84
总计 719
