简介
Use this guide to replace the door latch in your LG WM3050CW Washing Machine.
The door latch is electronically actuated. If your washer's door won't latch, you may need to replace this part.
你所需要的
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
Reach between the boot and the chassis to grip the door latch.
Pull the door latch toward the back of the device to remove it from its slot in the chassis.
Pull the latch towards the left edge of the device to completely expose it.
Disconnect the harness connector on the door latch.
Remove the door latch.
Repair didn’t go as planned? Ask our Answers community for help.
