跳转到主内容
LG Voyager Keyboard Replacement
你所需要的
  1. LG Voyager Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Keyboard Replacement: 步骤 2 中的图像 1,1
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Keyboard Replacement: 步骤 3 中的图像 1,1
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 LG Voyager Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • First remove the rubber stoppers covering the screws on the back of the phone by prying them up and away from the phone.
  5. LG Voyager Keyboard Replacement: 步骤 5 中的图像 1,2 LG Voyager Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the 3.61mm length, Phillips screws from the back of the phone using the #00 screwdriver.
  6. LG Voyager Keyboard Replacement: 步骤 6 中的图像 1,2 LG Voyager Keyboard Replacement: 步骤 6 中的图像 2,2
    • Now pry open the back of the phone.
    • Make sure that you use the plastic opening tool to go around the entire phone to help open the phone.
  7. LG Voyager Keyboard Replacement: 步骤 7 中的图像 1,2 LG Voyager Keyboard Replacement: 步骤 7 中的图像 2,2
    • Carefully separate the keyboard from the top of the phone.
    • Be careful not to break the ribbon cable.
  8. LG Voyager Keyboard Replacement: 步骤 8 中的图像 1,1
    • Detach the keyboard from the phone by taking off the little metal latches.
    • When replacing the old keyboard with a new one you will have to solder the metal latches to the new board.
结论
Lance Collins
于04/12/12注册
7 声望
撰写一个指南
团队
Cal Poly, Team 17-26, Amido Spring 2012 Cal Poly, Team 17-26, Amido Spring 2012 的会员
CPSU-AMIDO-S12S17G26
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 409
