你所需要的
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
Then press down on the bottom of the battery and it should snap into place
First remove the battery by pulling the tab away from the device
Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
另外一个人完成了本指南。
