跳转到主内容
加入维修社区 - 创建账户
LG Vortex Screen Replacement
你所需要的
    1. LG Vortex Screen Replacement, Power down the Phone: 步骤 1 中的图像 1,1
      • Power the phone off
      • The power button is located on top of the phone
      询问修复机器人
      添加评论
    2. LG Vortex Screen Replacement, Remove the Back Cover: 步骤 2 中的图像 1,3 LG Vortex Screen Replacement, Remove the Back Cover: 步骤 2 中的图像 2,3 LG Vortex Screen Replacement, Remove the Back Cover: 步骤 2 中的图像 3,3
      • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
      • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
      • Remove the back cover and set it to the side.
      询问修复机器人
      添加评论
    3. LG Vortex Screen Replacement: 步骤 3 中的图像 1,1
      • Remove the battery using the blue plastic opening tool.
      • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
      • Put the battery aside.
      询问修复机器人
      添加评论
    4. LG Vortex Screen Replacement, Unscrew the Back Frame: 步骤 4 中的图像 1,2 LG Vortex Screen Replacement, Unscrew the Back Frame: 步骤 4 中的图像 2,2
      • All screws are the same size screwdriver head #00
      • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
      • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
      • Place the screws in a container to ensure they aren't lost.
      添加评论
    5. LG Vortex Screen Replacement, Remove the Back Frame: 步骤 5 中的图像 1,3 LG Vortex Screen Replacement, Remove the Back Frame: 步骤 5 中的图像 2,3 LG Vortex Screen Replacement, Remove the Back Frame: 步骤 5 中的图像 3,3
      • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
      • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
      • Pry your way around the entire phone to separate the face from the frame.
      添加评论
    1. LG Vortex Screen Replacement, Screen: 步骤 6 中的图像 1,3 LG Vortex Screen Replacement, Screen: 步骤 6 中的图像 2,3 LG Vortex Screen Replacement, Screen: 步骤 6 中的图像 3,3
      • Unclip the screen connector that is connecting the screen to the system board. It is on the right side of the phone, and looks like a thin piece of bronze plastic.
      • Be gentle.
      询问修复机器人
      添加评论
    2. LG Vortex Screen Replacement: 步骤 7 中的图像 1,3 LG Vortex Screen Replacement: 步骤 7 中的图像 2,3 LG Vortex Screen Replacement: 步骤 7 中的图像 3,3
      • Pull the volume button away from the case and set aside. It is located on the left side of the phone, and is held to the frame by a small nub.
      询问修复机器人
      添加评论
    3. LG Vortex Screen Replacement: 步骤 8 中的图像 1,1
      • Pull the white piece underneath the volume button away from the frame.
      询问修复机器人
      添加评论
    4. LG Vortex Screen Replacement: 步骤 9 中的图像 1,2 LG Vortex Screen Replacement: 步骤 9 中的图像 2,2
      • Unscrew the two short black screws at the bottom of the phone, which are holding the USB port to the frame.
      • Place the screws in a safe place
      询问修复机器人
      添加评论
    5. LG Vortex Screen Replacement: 步骤 10 中的图像 1,3 LG Vortex Screen Replacement: 步骤 10 中的图像 2,3 LG Vortex Screen Replacement: 步骤 10 中的图像 3,3
      • Lift the system board up and away from the front screen
      • Caution! Perform this step slowly, because the two pieces will still be attached at the top of the phone.
      询问修复机器人
      添加评论
    6. LG Vortex Screen Replacement: 步骤 11 中的图像 1,3 LG Vortex Screen Replacement: 步骤 11 中的图像 2,3 LG Vortex Screen Replacement: 步骤 11 中的图像 3,3
      • Loosen the screen from the frame at one of four corners using a flat head screwdriver.
      • Look for small rectangle holes and use these to pry the LCD screen away from the face of the phone (the frame).
      • Remove the LCD screen.
      • Be sure not to touch or contaminate the LCD or the clear face with dust or your hands.
      询问修复机器人
      添加评论
      • Install new screen.
      • Important: Be extremely careful not to get the front screen or clear plastic face dirty- dust will affect the usability.
      询问修复机器人
      添加评论
    7. LG Vortex Screen Replacement: 步骤 13 中的图像 1,1
      • Reverse the steps to reassemble the phone.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jen
于02/13/14注册
40 声望
创作了3篇指南
团队
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G3
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 3,406
