跳转到主内容
加入维修社区 - 创建账户
LG Vortex Rear Facing Camera Replacement
你所需要的
  1. LG Vortex Rear Facing Camera Replacement, Power down the Phone: 步骤 1 中的图像 1,1
    • Power the phone off
    • The power button is located on top of the phone
  2. LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: 步骤 2 中的图像 1,3 LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: 步骤 2 中的图像 2,3 LG Vortex Rear Facing Camera Replacement, Remove the Back Cover: 步骤 2 中的图像 3,3
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. LG Vortex Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
  4. LG Vortex Rear Facing Camera Replacement, Unscrew the Back Frame: 步骤 4 中的图像 1,2 LG Vortex Rear Facing Camera Replacement, Unscrew the Back Frame: 步骤 4 中的图像 2,2
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
  5. LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: 步骤 5 中的图像 1,3 LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: 步骤 5 中的图像 2,3 LG Vortex Rear Facing Camera Replacement, Remove the Back Frame: 步骤 5 中的图像 3,3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
  6. LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: 步骤 6 中的图像 1,3 LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: 步骤 6 中的图像 2,3 LG Vortex Rear Facing Camera Replacement, Rear Facing Camera: 步骤 6 中的图像 3,3
    • This is the most difficult step.
    • Identify the system board (the main circuit board) inside, and locate the camera module area at the top.
    • You’ll see a black plastic component around the camera that’s seated on (but is not soldered to) the system board.
    • On each side of that black plastic piece, there are 2 black tabs securing it to the board. Gently pry these tabs outward (away from the board).
    • Hold them off the board, because they may snap back if released.
  7. LG Vortex Rear Facing Camera Replacement: 步骤 7 中的图像 1,1
    • Using the blue plastic prying tool remove the black piece next to the camera.
    • Be careful and avoid damaging the speaker cable that attaches the speakers to the motherboard.
  8. LG Vortex Rear Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Place a spudger or an opening tool under the edge of the camera connector and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Use a prying tool to lift the black camera housing away from the system board.
    • Work gradually along its edges, making sure not to tug on the cable.
  9. LG Vortex Rear Facing Camera Replacement: 步骤 9 中的图像 1,3 LG Vortex Rear Facing Camera Replacement: 步骤 9 中的图像 2,3 LG Vortex Rear Facing Camera Replacement: 步骤 9 中的图像 3,3
    • The camera module is secured by a small sticker or adhesive tab on its top.
    • Carefully pry this piece away with your fingernail, watching out for thin wires (e.g. wires connecting the board to speakers or other parts).
    • Once the adhesive is loosened, gently lift the camera straight up and off the board.
    • Pull the camera off the system board using your fingers. Perform this step with caution.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
Jen
于02/13/14注册
40 声望
创作了3篇指南
团队
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G3
4 名成员
创作了6篇指南
4指南评论
First, clean the cookware with water and a mild kitchen soap to remove anything that might be on the surface. Rinse with hot water. I do uk.bestessays.com and Then coat the entire bottom of the pan in vegetable oil in this case, canola oil and turn it over onto a paper towel for 10 minutes.
William Peter - 回复
Offer massages in my sanctuary or in the comfort of your own home
<a href="https://thecarriagehousesanctuary.square...">Top Massage Therapist in Westchester County NY</a>
Junaid Khan Akazai - 回复
Offer massages in my sanctuary or in the comfort of your own home <a href="https://thecarriagehousesanctuary.square...">Best Massage Therapist in Westchester County NY</a>
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 51
总计 556
