跳转到主内容
加入维修社区 - 创建账户
LG Versa Touch Screen Replacement
你所需要的
  1. LG Versa Touch Screen Replacement, LG Versa Teardown: 步骤 1 中的图像 1,1
    • Insert wisdom here.
  2. LG Versa Touch Screen Replacement: 步骤 2 中的图像 1,3 LG Versa Touch Screen Replacement: 步骤 2 中的图像 2,3 LG Versa Touch Screen Replacement: 步骤 2 中的图像 3,3
    • LG Versa has a 3" touchscreen with a call, power, and clr button on the front.
    • On left side you will find the volume control buttons and camera button. Also, the charger port.
    • On the other side you will find the microSD or microSDHC slot.
  3. LG Versa Touch Screen Replacement: 步骤 3 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 3 中的图像 2,2
    • The LG Versa has a 2.0 megapixel camera with a LED flash on the back
  4. LG Versa Touch Screen Replacement: 步骤 4 中的图像 1,1
    • On the right hand side of the LG Versa there is a latch to open up the back of the cell phone. Push the latch up and lift off the back of the phone exposing the battery.
  5. LG Versa Touch Screen Replacement: 步骤 5 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 5 中的图像 2,2
    • Simply insert your finger in between the slot and the battery and push down and up to remove the battery.
  6. LG Versa Touch Screen Replacement: 步骤 6 中的图像 1,1
    • Six Phillips screws holding down the battery housing (Circled in the picture). Unscrew the six screws and put them aside.
  7. LG Versa Touch Screen Replacement: 步骤 7 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 7 中的图像 2,2
    • Insert a safe prying tool between the slot between the front screen housing and the battery housing to remove the battery housing.
  8. LG Versa Touch Screen Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • In the bottom right corner of the logic board, disconnect the button connector with tweezers or a prying tool.
  9. LG Versa Touch Screen Replacement: 步骤 9 中的图像 1,1
    • Use a prying tool to safely lift up the logic board from the logic board housing
    • The logic board is connected to the speaker and the LCD screen from the back. Do not lift the logic board too high or you will have to replace the LCD screen and the speaker.
  10. LG Versa Touch Screen Replacement: 步骤 10 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 10 中的图像 2,2
    • The LCD screen is connected to the bottom of the logic board. Once you lift the logic board use tweezers or a safe prying tool to disconnect the ribbon wire from the LCD screen to the logic board.
  11. LG Versa Touch Screen Replacement: 步骤 11 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 11 中的图像 2,2
    • Lift the logic board carefully and use a safe prying tool and tweezers to remove the speaker.
    • The speaker is attached to the housing with a rubber adhesive be careful not to rip the wire from the logic board and the speak apart
  12. LG Versa Touch Screen Replacement: 步骤 12 中的图像 1,1
    • In the top right corner of the housing use a pry tool to disconnect the touch screen digitizer connector from the housing.
  13. LG Versa Touch Screen Replacement: 步骤 13 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 13 中的图像 2,2
    • Removing the logic board housing from the front housing is the most difficult part of the tear down.
    • Start on the side with the volume control buttons and use a safe pry tool to separate both housings.
  14. LG Versa Touch Screen Replacement: 步骤 14 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 14 中的图像 2,2
    • Use the safe pry tool around the perimeter of the phone until you are able to separate both housing apart.
    • Remove the Lock, Volume, and Front buttons from the housing.
  15. LG Versa Touch Screen Replacement: 步骤 15 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 15 中的图像 2,2
    • Simply lift the LCD screen from the logic board housing to remove the LCD screen.
  16. LG Versa Touch Screen Replacement: 步骤 16 中的图像 1,1
    • Congratulations you have fully torn down the LG Versa.
  17. LG Versa Touch Screen Replacement, Touch Screen: 步骤 17 中的图像 1,1
    • Use a safe prying tool and pry around the perimeter until the screen is separated from the housing.
  18. LG Versa Touch Screen Replacement: 步骤 18 中的图像 1,2 LG Versa Touch Screen Replacement: 步骤 18 中的图像 2,2
    • Using your thumbs, push the glass screen off the housing and pull the screen off.
    • Be carful to not rip the ribbon cable while taking the screen off. There is a hole in the top left corner of the housing where the ribbon cable should be pulled out.
  19. LG Versa Touch Screen Replacement: 步骤 19 中的图像 1,1
    • Apply super glue around the edge of the housing where the class will sit.
  20. LG Versa Touch Screen Replacement: 步骤 20 中的图像 1,1
    • Put the ribbon cable through the hold and place your new touch screen inside the housing.
  21. LG Versa Touch Screen Replacement: 步骤 21 中的图像 1,1
    • Push the housing and the glass together. Wait 5-10 minutes for glue to dry.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 6,738
