跳转到主内容
加入维修社区 - 创建账户
LG VX9800 Front Keypad Replacement
你所需要的
  1. LG VX9800 Front Keypad Replacement, Front Keypad: 步骤 1 中的图像 1,1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Front Keypad Replacement: 步骤 2 中的图像 1,1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Front Keypad Replacement: 步骤 3 中的图像 1,1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Front Keypad Replacement: 步骤 4 中的图像 1,1
    • Starting on the side with red square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Front Keypad Replacement: 步骤 5 中的图像 1,2 LG VX9800 Front Keypad Replacement: 步骤 5 中的图像 2,2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
    • Lift the dislodged faceplate off the motherboard while being mindful of the wires still attached to it.
  6. LG VX9800 Front Keypad Replacement: 步骤 6 中的图像 1,3 LG VX9800 Front Keypad Replacement: 步骤 6 中的图像 2,3 LG VX9800 Front Keypad Replacement: 步骤 6 中的图像 3,3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Front Keypad Replacement: 步骤 7 中的图像 1,1
    • The faceplate and keypad can now be completely removed from the phone.
终点
Aaron Rowley
于01/21/10注册
33 声望
创作了2篇指南
团队
Cal Poly, Team 16-32, Maness Winter 2010 Cal Poly, Team 16-32, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G32
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 44
总计 2,040
