跳转到主内容
LG VX8700 Front Bezel Replacement
你所需要的
  1. LG VX8700 Front Bezel Replacement, Battery: 步骤 1 中的图像 1,2 LG VX8700 Front Bezel Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Front Bezel Replacement: 步骤 2 中的图像 1,2 LG VX8700 Front Bezel Replacement: 步骤 2 中的图像 2,2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Front Bezel Replacement, Front Bezel: 步骤 3 中的图像 1,1
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  4. LG VX8700 Front Bezel Replacement: 步骤 4 中的图像 1,2 LG VX8700 Front Bezel Replacement: 步骤 4 中的图像 2,2
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  5. LG VX8700 Front Bezel Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  6. LG VX8700 Front Bezel Replacement: 步骤 6 中的图像 1,2 LG VX8700 Front Bezel Replacement: 步骤 6 中的图像 2,2
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
结论
团队
Cal Poly, Team 8-16, Maness Winter 2012 Cal Poly, Team 8-16, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G16
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 989
