跳转到主内容
LG VX8560 Side Key Replacement
你所需要的
  1. LG VX8560 Side Key Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: 步骤 2 中的图像 1,1
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: 步骤 3 中的图像 1,2 LG VX8560 Side Key Replacement: 步骤 3 中的图像 2,2
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: 步骤 4 中的图像 1,2 LG VX8560 Side Key Replacement, Side Keys: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: 步骤 5 中的图像 1,3 LG VX8560 Side Key Replacement: 步骤 5 中的图像 2,3 LG VX8560 Side Key Replacement: 步骤 5 中的图像 3,3
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: 步骤 6 中的图像 1,2 LG VX8560 Side Key Replacement: 步骤 6 中的图像 2,2
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
结论
另外一个人完成了本指南。
Kevin
于04/18/13注册
7 声望
创作了2篇指南
团队
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G62
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 10
总计 221
