跳转到主内容
LG VX8550 Speaker Replacement
你所需要的
  1. LG VX8550 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release up.
  2. LG VX8550 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Speaker Replacement, Case: 步骤 3 中的图像 1,1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Speaker Replacement: 步骤 6 中的图像 1,1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Speaker Replacement: 步骤 7 中的图像 1,1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Speaker Replacement, Speaker: 步骤 8 中的图像 1,1
    • With the back casing removed the speaker is visible.
  9. LG VX8550 Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift up under top end of circuit board with the Spludger to access retaining clip.
  10. LG VX8550 Speaker Replacement: 步骤 10 中的图像 1,1
    • Carefully pry up on retaining clip with the Spudger to release the speaker.
  11. LG VX8550 Speaker Replacement: 步骤 11 中的图像 1,1
    • Carefully unplug speaker connector from circuit board with your fingers.
  12. LG VX8550 Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the speaker by lifting up.
结论
Nathan Jones
于04/10/10注册
89 声望
创作了10篇指南
团队
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G55
5 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 2,016
