跳转到主内容
LG VX8550 Motherboard Replacement
你所需要的
  1. LG VX8550 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release up.
  2. LG VX8550 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Motherboard Replacement, Case: 步骤 3 中的图像 1,1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard from the front casing by lifting straight up.
结论
Nathan Jones
于04/10/10注册
89 声望
创作了10篇指南
团队
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G55
5 名成员
创作了20篇指南
一条评论
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
http://harrypotter1081.livejournal.com/
Harry Potter - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,497
