跳转到主内容
加入维修社区 - 创建账户
LG VX8350R Keypad Replacement
你所需要的
  1. LG VX8350R Keypad Replacement, Keypad: 步骤 1 中的图像 1,3 LG VX8350R Keypad Replacement, Keypad: 步骤 1 中的图像 2,3 LG VX8350R Keypad Replacement, Keypad: 步骤 1 中的图像 3,3
    • Using your thumb, slide battery cover off in a downward direction.
  2. LG VX8350R Keypad Replacement: 步骤 2 中的图像 1,2 LG VX8350R Keypad Replacement: 步骤 2 中的图像 2,2
    • Place the plastic opening tool at the top of the battery and pry it out to remove. Set the battery aside.
  3. LG VX8350R Keypad Replacement: 步骤 3 中的图像 1,1
    • With a Phillips #00 Screwdriver, remove the four screws in a counter-clockwise direction from the back cover. Set them aside on a surface where they won't roll away; these screws will be used in reassembly.
  4. LG VX8350R Keypad Replacement: 步骤 4 中的图像 1,3 LG VX8350R Keypad Replacement: 步骤 4 中的图像 2,3 LG VX8350R Keypad Replacement: 步骤 4 中的图像 3,3
    • Using the plastic opening tool, carefully pry off the back cover. You may need to use the opening tool around the entire edge of the back cover to remove completely.
    • You will have to use some force to remove the upper part of the back cover. Apply enough force to separate the pieces without cracking the back cover.
  5. LG VX8350R Keypad Replacement: 步骤 5 中的图像 1,2 LG VX8350R Keypad Replacement: 步骤 5 中的图像 2,2
    • Gently lift the green computer chip plate out of the way to expose the keypad.
    • The green computer chip plate cannot be completely removed. It is attached to the phone by a ribbon. Be careful not to break this ribbon when moving the green computer chip plate.
  6. LG VX8350R Keypad Replacement: 步骤 6 中的图像 1,3 LG VX8350R Keypad Replacement: 步骤 6 中的图像 2,3 LG VX8350R Keypad Replacement: 步骤 6 中的图像 3,3
    • Remove the keypad using your fingers and set aside.
  7. LG VX8350R Keypad Replacement: 步骤 7 中的图像 1,3 LG VX8350R Keypad Replacement: 步骤 7 中的图像 2,3 LG VX8350R Keypad Replacement: 步骤 7 中的图像 3,3
    • Align the small holes in the new keypad with the posts on the phone.
  8. LG VX8350R Keypad Replacement: 步骤 8 中的图像 1,3 LG VX8350R Keypad Replacement: 步骤 8 中的图像 2,3 LG VX8350R Keypad Replacement: 步骤 8 中的图像 3,3
    • When replacing the computer chip, the sensor bar for the volume button may pop out of place. If this occurs, gently push the bars back into place behind the buttons with your fingers.
结论
另外一个人完成了本指南。
Alex Goots
于09/24/13注册
117 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 18
总计 525
