跳转到主内容
LG VX8350 Repair Keypad Removal
你所需要的
  1. LG VX8350 Repair Keypad Removal, Battery: 步骤 1 中的图像 1,2 LG VX8350 Repair Keypad Removal, Battery: 步骤 1 中的图像 2,2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. LG VX8350 Repair Keypad Removal: 步骤 2 中的图像 1,2 LG VX8350 Repair Keypad Removal: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. LG VX8350 Repair Keypad Removal, Circuit Board Housing: 步骤 3 中的图像 1,3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: 步骤 3 中的图像 2,3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: 步骤 3 中的图像 3,3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. LG VX8350 Repair Keypad Removal: 步骤 4 中的图像 1,2 LG VX8350 Repair Keypad Removal: 步骤 4 中的图像 2,2
    • Lift the back cover starting at the bottom of the phone.
  5. LG VX8350 Repair Keypad Removal: 步骤 5 中的图像 1,2 LG VX8350 Repair Keypad Removal: 步骤 5 中的图像 2,2
    • Remove the back cover completely from the phone.
  6. LG VX8350 Repair Keypad Removal, Circuit Board: 步骤 6 中的图像 1,1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. LG VX8350 Repair Keypad Removal: 步骤 7 中的图像 1,2 LG VX8350 Repair Keypad Removal: 步骤 7 中的图像 2,2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. LG VX8350 Repair Keypad Removal, Keypad: 步骤 8 中的图像 1,2 LG VX8350 Repair Keypad Removal, Keypad: 步骤 8 中的图像 2,2
    • Lift the keyboard and remove it from the phone.
结论
James Brandon
于10/18/13注册
201 声望
创作了2篇指南
团队
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G7
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 277
