跳转到主内容
LG VX8300 Number Pad Removal for Replacement or Cleaning
你所需要的
  1. LG VX8300 Number Pad Removal for Replacement or Cleaning, Disassembling LG VX8300 Body: 步骤 1 中的图像 1,3 LG VX8300 Number Pad Removal for Replacement or Cleaning, Disassembling LG VX8300 Body: 步骤 1 中的图像 2,3 LG VX8300 Number Pad Removal for Replacement or Cleaning, Disassembling LG VX8300 Body: 步骤 1 中的图像 3,3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
  2. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 2 中的图像 1,2 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 2 中的图像 2,2
    • Place your finger into the semicircle gap on top of the battery.
    • Apply force downward and out, so the battery pops out of the phone.
  3. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 3 中的图像 1,3 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 3 中的图像 2,3 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
    • Use tweezers to lift and remove the rubber pads.
  4. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 4 中的图像 1,2 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
  5. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 5 中的图像 1,2 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 5 中的图像 2,2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached. The logic board is now fully accessible.
    • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
  6. LG VX8300 Number Pad Removal for Replacement or Cleaning, Number Pad: 步骤 6 中的图像 1,1
    • Holding the chassis firmly in one hand, then lift up on the charging port with the edge of an opening tool to separate the logic board from the front body case.
    • Use the spudger tool to gently lift the board out of the case. The board is secured by six holes around its perimeter and will become free when pried from the supports.
  7. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 7 中的图像 1,3 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 7 中的图像 2,3 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 7 中的图像 3,3
    • Without putting tension on the wiring, remove the speakers one at a time.
    • Remove the ribbon cable by lifting it up with your finger. Set it aside.
    • Remove the logic board completely from the case and set it aside. You can now remove the button pad with your fingers or the spudger tool.
  8. LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 8 中的图像 1,2 LG VX8300 Number Pad Removal for Replacement or Cleaning: 步骤 8 中的图像 2,2
    • Cleaning: You may use a brush to remove debris between individual buttons. Use a soft cloth to clean the underside of the pad.
    • Replacing: Remove the old pad and insert the new pad into the case.
结论
Follow these instructions in reverse order to reassemble the device.
nvalm
于03/23/15注册
448 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-7, Duarte Spring 2015 UMass Dartmouth, Team 3-7, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 289
