跳转到主内容
LG VX8300 Battery Replacement
  1. LG VX8300 Battery Replacement, Battery Replacement: 步骤 1 中的图像 1,3 LG VX8300 Battery Replacement, Battery Replacement: 步骤 1 中的图像 2,3 LG VX8300 Battery Replacement, Battery Replacement: 步骤 1 中的图像 3,3
    • Power off the device by holding down the power button.
    • Remove the battery cover by pushing down on the solid lines at the top of the cover. Then simply slide the cover down till it is completely removed.
  2. LG VX8300 Battery Replacement: 步骤 2 中的图像 1,3 LG VX8300 Battery Replacement: 步骤 2 中的图像 2,3 LG VX8300 Battery Replacement: 步骤 2 中的图像 3,3
    • Place your finger into the semicircle gap at the top of the battery, then push down and pull so the battery pops out.
  3. LG VX8300 Battery Replacement: 步骤 3 中的图像 1,1
    • Wipe down the battery compartment to remove any debris or battery acid. Avoid contact with battery acid as it can damage your eyes or skin.
  4. LG VX8300 Battery Replacement: 步骤 4 中的图像 1,1
    • Insert the new Lithium Ion 3.7V 1100mAh battery into the compartment.
结论
After you finish replacing the battery make sure you put the battery cover back on and you will be all set.
nvalm
于03/23/15注册
448 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-7, Duarte Spring 2015 UMass Dartmouth, Team 3-7, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 528
