简介
Learn to remove the housing of the LG VX8300 and gain access to the back panel where the antenna is located.
你所需要的
Power off the device by holding down the red button labeled PWR.
Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
Place the phone in front of you. With the antenna in the top right corner, and the opened back panel facing up.
Use a Phillips #00 Screwdriver to remove the single 2mm x 3mm screw. Found on the gold band, just underneath the antenna.
You have now successfully completed the antenna replacement for an LG VX8300 flip phone.
