当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
Use the Phillips #00 and remove the four screws on the lower backside of the phone.
Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
Remove the motherboard. Do not remove other components.
Insert the new motherboard with the white side facing down.
Make sure the side buttons on motherboard are correctly aligned to avoid future complications.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
