简介
Phone lacking intelligence? Replace your logic board.
配件
无需配件。
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove four screws beneath battery using screw driver.
    • Remove four screws beneath battery using screw driver.
    • Remove three rubber screw covers with tweezers.
    • Remove the three screws under the covers with the screwdriver.
  5. Detach outer casing from back of phone.
    • Detach outer casing from back of phone.
    • NOTE: There will be a significant amount of resistance to detaching the back casing.
  6. Unsnap gold rectangular plate and silver square plate from the logic board.
    • Unsnap gold rectangular plate and silver square plate from the logic board.
  7. Remove logic board, being careful not to remove any other pieces.
    • Remove logic board, being careful not to remove any other pieces.
    • Insert new logic board with white side facing down.
    • NOTE: Make sure side buttons on logic board are correctly aligned to avoid future complications.
结论
Nichole Shaw
于2010年04月13日注册
1 信誉积分
创作了7篇指南
团队
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G75
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,240
