当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Lay the phone, screen side down, in your palm.
Slide the grey button towards the top of the phone.
With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
Locate four screws underneath of the battery.
Remove screws by turning counter clockwise with screwdriver until they pop out.
Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
Note: There will be a significant amount of resistance.
Lift up logic board without completely removing from phone.
Remove entire keypad from beneath the logic board.
Insert replacement keypad with buttons aligned in proper holes.
取消:我没有完成这个指南。
与2其他贡献者
于04/13/10注册
1 声望
创作了7篇指南
徽章: 4
+1个徽章
CPSU-JOHANN-S10S18G75
4 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 1,055
