跳转到主内容
LG VX7000 Keypad Replacement
你所需要的
  1. LG VX7000 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. LG VX7000 Keypad Replacement: 步骤 2 中的图像 1,1
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. LG VX7000 Keypad Replacement, Keypad: 步骤 3 中的图像 1,1
    • Locate four screws underneath of the battery.
    • Remove screws by turning counter clockwise with screwdriver until they pop out.
  4. LG VX7000 Keypad Replacement: 步骤 4 中的图像 1,1
    • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Note: There will be a significant amount of resistance.
  5. LG VX7000 Keypad Replacement: 步骤 5 中的图像 1,1
    • Lift up logic board without completely removing from phone.
    • Remove entire keypad from beneath the logic board.
  6. LG VX7000 Keypad Replacement: 步骤 6 中的图像 1,1
    • Insert replacement keypad with buttons aligned in proper holes.
结论
Nichole Shaw
于04/13/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G75
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,048
