跳转到主内容
LG VX7000 Internal LCD Screen Replacement
你所需要的
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: 步骤 1 中的图像 1,1
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Align new face plate in correct orientation in order to install.
结论
Nichole Shaw
于04/13/10注册
1 声望
创作了7篇指南
团队
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G75
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 11
总计 2,229
