跳转到主内容
修复你的物品
维修的权力
商店
简介
Phone won't charge, and the charger is functional? Replace your phone's charging adapter.
NOTE: Charging adapter is attached to the logic board, so replacement requires replacing the logic board.
配件
没有特定配件。
  1. Lay the phone, screen side down, in your palm.
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. Use the Phillips #00  and remove the four screws on the lower backside of the phone.
    • Use the Phillips #00 and remove the four screws on the lower backside of the phone.
    • Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
  4. Detach the outer casing from the back of the phone.
    • Detach the outer casing from the back of the phone.
    • There will be a significant amount of resistance to detaching the back casing.
  5. Unsnap the gold rectangular connector and silver square connector from the motherboard.
    • Unsnap the gold rectangular connector and silver square connector from the motherboard.
  6. Remove the motherboard. Do not remove other components.
    • Remove the motherboard. Do not remove other components.
    • Insert the new motherboard with the white side facing down.
    • Make sure the side buttons on motherboard are correctly aligned to avoid future complications.
  7. Replace logic board to replace charging adapter.
    • Replace logic board to replace charging adapter.
结论
Nichole Shaw
于2010年04月13日注册
1 信誉积分
创作了7篇指南
团队
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G75
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,402
