跳转到主内容
LG VX6100 Speaker Replacement
你所需要的
  1. LG VX6100 Speaker Replacement, Front Case: 步骤 1 中的图像 1,1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Speaker Replacement: 步骤 3 中的图像 1,1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Speaker Replacement: 步骤 4 中的图像 1,1
    • The case can now be removed and the interior of the front is accessible.
  5. LG VX6100 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 LG VX6100 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Locate the four solder joints (connected to the yellow, black, blue, and red wires) on the bottom part of the phone, connected to the speaker. It will appear as a black circular part with some holes in it.
    • Place a piece of solder wick on top of the solders.
    • Very carefully, place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • Soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
  6. LG VX6100 Speaker Replacement: 步骤 6 中的图像 1,1
    • After the solder has been removed, pry out the speaker with the plastic opening tool.
结论
Ryan Bishop
于04/17/12注册
1 声望
创作了3篇指南
团队
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G39
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 510
