跳转到主内容
加入维修社区 - 创建账户
LG VX6100 Keypad Replacement
你所需要的
  1. LG VX6100 Keypad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Push down on the gray "PUSH" button on the back side of the phone.
    • Slide the back case downward. Then, lift and remove the case.
  2. LG VX6100 Keypad Replacement: 步骤 2 中的图像 1,1
    • Lift up on the battery to remove it from the case.
  3. LG VX6100 Keypad Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a push-pin or tweezers to pry both of the tear-shaped screw covers out of the top of the phone.
  4. LG VX6100 Keypad Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the six case screws from the back of the phone.
  5. LG VX6100 Keypad Replacement: 步骤 5 中的图像 1,2 LG VX6100 Keypad Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opener tool through the seam between the back case and the rest of the phone.
    • Slowly slide the tool along the seam. Lift up on the back case while you do this until the back case comes apart.
  6. LG VX6100 Keypad Replacement, Keypad: 步骤 6 中的图像 1,1
    • Lift the bottom of the logic board out of the case.
    • Make sure not to lift the top of the logic board, since it is still connected to the backcase of the phone.
  7. LG VX6100 Keypad Replacement: 步骤 7 中的图像 1,1
    • Gently lift up on any edge of the white keypad to remove it from the phone case.
结论
Teal
于04/17/12注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G39
3 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 59
总计 762
