跳转到主内容
加入维修社区 - 创建账户
LG VX6000 Screen Replacement
你所需要的
  1. LG VX6000 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the dark gray tab on the back of the phone.
    • Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Screen Replacement: 步骤 2 中的图像 1,1
    • Lift and rotate the battery away from the bottom edge.
    • Remove the battery.
  3. LG VX6000 Screen Replacement, Body: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Screen Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
    • Place the screws on an uncluttered surface or in a small container.
  5. LG VX6000 Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the back of the phone with your fingernails or tweezers.
    • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
    • The red and blue wires must be plugged in to reassemble.
  6. LG VX6000 Screen Replacement, Logic Board: 步骤 6 中的图像 1,1
    • Carefully peel away the adhesive tab.
    • The tab should not be completely separated from the phone.
  7. LG VX6000 Screen Replacement: 步骤 7 中的图像 1,2 LG VX6000 Screen Replacement: 步骤 7 中的图像 2,2
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Carefully pry the connector away from the motherboard to remove it from the phone.
    • Do not pull forcefully
  8. LG VX6000 Screen Replacement: 步骤 8 中的图像 1,1
    • Gently lift the corner of the motherboard away from the casing.
  9. LG VX6000 Screen Replacement, Screen: 步骤 9 中的图像 1,3 LG VX6000 Screen Replacement, Screen: 步骤 9 中的图像 2,3 LG VX6000 Screen Replacement, Screen: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a paper clip or tweezers, pop out the screen by pressing the plastic tab in the top-left corner of the phone's bottom casing as indicated in the photo.
    • Be careful not to lose the tab that pops out. It is a small and clear piece of plastic.
    • The tab is fragile, handle with care.
  10. LG VX6000 Screen Replacement: 步骤 10 中的图像 1,3 LG VX6000 Screen Replacement: 步骤 10 中的图像 2,3 LG VX6000 Screen Replacement: 步骤 10 中的图像 3,3
    • As shown in the photos, pull the orange strip through a thin opening at the top of the phone. Once this is done, the top and bottom halves can be separated.
  11. LG VX6000 Screen Replacement: 步骤 11 中的图像 1,1
    • Set the bottom half of the phone aside.
    • Using tweezers, pull off the small rubber cushions located towards the four corners of the screen.
  12. LG VX6000 Screen Replacement: 步骤 12 中的图像 1,1
    • With a Phillips tip screwdriver, unscrew the four newly exposed screws.
    • Keep screws from the different steps in different locations so as to not mix them up.
  13. LG VX6000 Screen Replacement: 步骤 13 中的图像 1,3 LG VX6000 Screen Replacement: 步骤 13 中的图像 2,3 LG VX6000 Screen Replacement: 步骤 13 中的图像 3,3
    • Carefully open the casing using the iFixit plastic tool by prying each side a little bit at a time. Rotate and open until all the inside clips pop open and the casing opens up.
  14. LG VX6000 Screen Replacement: 步骤 14 中的图像 1,2 LG VX6000 Screen Replacement: 步骤 14 中的图像 2,2
    • After you pry open the casing, you will be left with the screen and circuit board in the top face plate.
    • Gently pull the corner of screen and circuit board up and out of casing to remove screen from the top face plate.
    • Do not try to completely separate the circuit board from the casing. There are still wires connecting the two.
  15. LG VX6000 Screen Replacement: 步骤 15 中的图像 1,1
    • Rotate the screen and the connected white frame away from the logic board.
    • Carefully peel the adhesive tape that connects the screen and logic board off. The screen can now be removed and replaced with a new screen unit.
结论
Adam Altman
于01/14/10注册
1 声望
创作了3篇指南
团队
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G11
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 2,878
