当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Carefully remove the back of the phone gently using your fingernails or tweezers.
There are a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
To reattach the back, you must plug these wires back in.
Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
Remove the connector by carefully prying it away from the motherboard and lifting it away from the phone
Do not pull too hard on the connector.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
