跳转到主内容
加入维修社区 - 创建账户
LG VX6000 Keyboard Replacement
你所需要的
  1. LG VX6000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the dark gray tab on the back of the phone.
    • Push the tab towards the top of the phone to release the battery.
  2. LG VX6000 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift and rotate the battery away from the bottom edge.
    • Remove the battery.
  3. LG VX6000 Keyboard Replacement, Body: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully use tweezers to remove the two rubber cushions located at the top of the phone.
    • Only remove the two cushions that are circled!
  4. LG VX6000 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six screws highlighted on the back of the phone.
    • Place the screws on an uncluttered surface or in a small container.
  5. LG VX6000 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the back of the phone with your fingernails or tweezers.
    • There are red and blue wires connected to the motherboard. Forcing the components apart could damage the wires.
    • The red and blue wires must be plugged in to reassemble.
  6. LG VX6000 Keyboard Replacement, Logic Board: 步骤 6 中的图像 1,1
    • Carefully peel away the adhesive tab.
    • The tab should not be completely separated from the phone.
  7. LG VX6000 Keyboard Replacement: 步骤 7 中的图像 1,2 LG VX6000 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Locate the yellow connection towards the top of the phone. This is directly connected to the screen.
    • Carefully pry the connector away from the motherboard to remove it from the phone.
    • Do not pull forcefully
  8. LG VX6000 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Gently lift the corner of the motherboard away from the casing.
  9. LG VX6000 Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Peel the keypad off the casing.
    • Swap out the old keypad for a new one.
结论
Adam Altman
于01/14/10注册
1 声望
创作了3篇指南
团队
Cal Poly, Team 4-11, Forte Winter 2010 Cal Poly, Team 4-11, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G11
5 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 2,869
