当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
Some of the pictures show the bottom of the phone disassembled. It is unneccessary to disassemble the bottom of the phone for this guide.
Hold the opened phone upright.
Use the spudger to pry around the edges of the phone and detach the tabs.
Make sure all the tabs around the grey cover are detached. They are located on the top and on both sides of the screen.
Use your finger to lift up the grey plastic cover.
Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
The plastic screen protector is adhered with glue to the back of the phone, so a little force is required to remove it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
