简介
The screens for the LG VX5600 come together as a single unit inside the phone therefore to replace one you will be replacing the other.
你所需要的
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
在这个步骤中使用的工具:Tweezers$4.99
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located in the upper left and right hand corners.
3等其他人完成本指南。
1指南评论
just swapped screens Perfect. step 5 is harder than it look but take time and go easy, I used a 1/8 in blade screwdriver.
