跳转到主内容
LG VX5500 Screen Replacement
你所需要的
  1. LG VX5500 Screen Replacement, Battery: 步骤 1 中的图像 1,3 LG VX5500 Screen Replacement, Battery: 步骤 1 中的图像 2,3 LG VX5500 Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Screen Replacement, Screen: 步骤 2 中的图像 1,2 LG VX5500 Screen Replacement, Screen: 步骤 2 中的图像 2,2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. LG VX5500 Screen Replacement: 步骤 3 中的图像 1,2 LG VX5500 Screen Replacement: 步骤 3 中的图像 2,2
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. LG VX5500 Screen Replacement: 步骤 4 中的图像 1,3 LG VX5500 Screen Replacement: 步骤 4 中的图像 2,3 LG VX5500 Screen Replacement: 步骤 4 中的图像 3,3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. LG VX5500 Screen Replacement: 步骤 5 中的图像 1,2 LG VX5500 Screen Replacement: 步骤 5 中的图像 2,2
    • Use the tweezers to lift the display adapter off the screen component.
  6. LG VX5500 Screen Replacement: 步骤 6 中的图像 1,2 LG VX5500 Screen Replacement: 步骤 6 中的图像 2,2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. LG VX5500 Screen Replacement: 步骤 7 中的图像 1,2 LG VX5500 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. LG VX5500 Screen Replacement: 步骤 8 中的图像 1,2 LG VX5500 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. LG VX5500 Screen Replacement: 步骤 9 中的图像 1,1
    • Lift the screen components out of the phone.
结论
3等其他人完成本指南。
Henry
于04/12/12注册
181 声望
创作了3篇指南
团队
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G33
4 名成员
创作了10篇指南
2条评论
I have it apart know need to learn to solder!
Andy Fowler - 回复
where can i purchase a replacement screen?
kalea dean - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,739
