跳转到主内容
LG VX5500 Mother Board Replacement
你所需要的
  1. LG VX5500 Mother Board Replacement, Battery: 步骤 1 中的图像 1,3 LG VX5500 Mother Board Replacement, Battery: 步骤 1 中的图像 2,3 LG VX5500 Mother Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Mother Board Replacement, Mother Board: 步骤 2 中的图像 1,2 LG VX5500 Mother Board Replacement, Mother Board: 步骤 2 中的图像 2,2
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. LG VX5500 Mother Board Replacement: 步骤 3 中的图像 1,3 LG VX5500 Mother Board Replacement: 步骤 3 中的图像 2,3 LG VX5500 Mother Board Replacement: 步骤 3 中的图像 3,3
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. LG VX5500 Mother Board Replacement: 步骤 4 中的图像 1,2 LG VX5500 Mother Board Replacement: 步骤 4 中的图像 2,2
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. LG VX5500 Mother Board Replacement: 步骤 5 中的图像 1,2 LG VX5500 Mother Board Replacement: 步骤 5 中的图像 2,2
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
结论
2等其他人完成本指南。
Henry
于04/12/12注册
181 声望
创作了3篇指南
团队
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 的会员
CPSU-MANESS-S12S7G33
4 名成员
创作了10篇指南
2条评论
You guys are great!
Kurt Beske - 回复
So what do you do with the mother board then?
Erik Sodders - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,123
